Введение
Replace the motherboard of the camera, located underneath the back cover.
Выберете то, что вам нужно
Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
Use your fingers to lift the plastic viewfinder cover upward.
Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to pull the five ribbon cables horizontally out of their clips.
Use a spudger or your fingernail to flip up the four, small retaining flap, or zero insertion force (ZIF) connectors. Then, pull the ribbon cable out to disconnect it.
Remove the green tape using your fingernail. Then, use a spudger to pry the one antenna cable connector straight up from the board.
Use tweezers or a spudger to pry up each side of the flat-topped connector. Then, lift the one connector straight up from its socket.
Use tweezers or your fingers to pull the two double-bundled cables up and away from the connector in the same direction that the individual wires are running.
Use a spudger to lift the motherboard up starting on the right side proceeding to the left side.
Use your fingers to lift the motherboard completely out of the camera.
4 участников успешно повторили данное руководство.
4 Комментариев
Hi this was very informative, bt do you know where i can find a replacemen mainboard ?...i've been looking but no luck
Hi all
Does anyone know where can I found the service manual for this camera? I really need it!!! I need to take off the upper buttons and the upper LCD screen!!!
Thanks in advance.
Sotirios Konstantinou
sotsma@gmail.com
Hello, the mode switch does not function well. I want to buy a top cover complete with all the switches. Please tell me how to replace this cover. Thank.
