Введение
If you need to replacement your front lens, here is the guide to do so. Be sure to turn off your camera and take out the battery before you being your replacement.
Выберете то, что вам нужно
Unscrew the four 5.5 mm #000 Philips screws that are on the metal ring with a Philips #000 screwdriver.
Remove the three 4.5 mm Phillips #000 head screws located inside the cover with a Phillips #000 screwdriver.
Еще один человек закончил это руководство.
