Введение
This guide will show you how to replace the lens assembly on the Samsung NX2000. It will show you a step by step replacement guide of how to remove parts of lens successfully. Begin with making sure your camera is turned off and removing the lens.
Выберете то, что вам нужно
Begin by pressing the lens lock button to the right of the lens.
Release the button and turn the lens in a clockwise motion until you have removed the lens.
Make sure your camera is turned off and flip your device upside down.
Slide the battery switch to the left and open the battery compartment.
Push the blue button up inside the battery compartment and remove the battery.
Remove the four 4mm screws highlighted here with the Y0 screwdriver.
Using a tweezer, gently remove the outer silver lens lining.
Underneath will lie a black ring, which needs to removed using the same tweezer.
Remove the final silver ring from the lens assembly using a tweezer.
Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
Remove the spring from the same compartment using the same tool.
Еще один человек закончил это руководство.
