Введение
If your home and play buttons are not working on your Samsung NX2000, we are here to show you step-by-step how you can replace them yourself. It will connect with the previous LCD display replacement guide and show you the correct way to remove this button.
Выберете то, что вам нужно
First begin by flipping your camera upside down.
Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
Before taking it apart you'll have to detach the display ribbon cable.
Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
Detach the two ribbon cables, by first lifting the black tab on top of the connector.
Pull the ribbon cables out of the connectors with tweezers or two fingers.
Place blue plastic spudger in between LCD screen and plastic surrounding.
Begin to lift up slowly, removing the LCD screen from the main frame.
Еще один человек закончил это руководство.
