Введение
This guide will show you how to replace the jog and mode dials on the top panel assembly of the NX300.
Запчасти
Никакие детали не требуются.
Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
Using a Phillips #00 precision screwdriver, remove the last 4mm screw located inside the input ports' compartment.
Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
Using a Phillips #00 precision screwdriver, remove the 3mm screw holding the top panel of the camera in place. Also, remove the screws under hot shoe metal clip, otherwise you can break a piece of sensor frame leading to costly repair.
Using a plastic opening tool, carefully remove the top panel of the camera.
Using a Phillips #00 precision screwdriver, remove the three 4mm screws holding the power switch board in place.
Using tweezers, gently pull the ribbon cable out of the power switch board.
Using a Phillips #00 precision screwdriver, remove the 4mm screw holding the jog dial in place.
Using tweezers, gently remove the ribbon cable attached to the jog dial.
The jog dial should fall out easily. If not, use a pair of tweezers to gently poke it though the power board.
Using a Phillips #00 precision screwdriver, remove the four 3mm screws holding the mode dial and power switch/shutter button in place.
Remove the metal mounts from the underside of the dials. The dials are now free from the camera.
7 участников успешно повторили данное руководство.
Комментариев: 3
Thanks, this was useful. Camera was switching modes randomly. I didn't replace the PCB however, just opened and sprayed a lot of silicon oil into the dial.
