Введение
Should either the memory card reader, USB or HDMI ports become unresponsive or otherwise damaged, it will be necessary to replace the motherboard. This guide will show how to replace the camera's motherboard.
Выберете то, что вам нужно
Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
Using a Phillips #00 precision screwdriver, remove the three 4mm screws holding the motherboard in place.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers or a plastic opening tool, release the locks on the ribbon receptors by flicking up the black bars on the holds. Pull the five ribbons away from the motherboard (one hidden from view). This will free the motherboard completely from the device.
The motherboard is now free. Pull the motherboard up and slightly away from the input compartment; it will lift out easily.
7 участников успешно повторили данное руководство.
5 Комментариев
any suggestions where to get the board? i oly found one on aliexpress for $100
What is the price of motheboard
