Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
Slide the button to the left to open the battery compartment.
Push the blue button up to release the battery.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Remove the four 7.3 mm Phillips screws from the front of the lens assembly.
Remove the silver ring with tweezers.
Use tweezers to remove the black plastic ring and small metal ring inside the lens assembly.
Use tweezers to lift the pyramid screw and spring from the lens assembly.
Remove the three 4.3 mm Phillips screws from the bottom of the camera.
Remove the 4.3 mm Phillips screw hiding inside the battery compartment.
Remove the 4.2 mm Phillips screw from the left handgrip.
Remove the two 4.2 mm Phillips screws from the right handgrip.
Use tweezers to remove the metal shield from the external flash mount.
Remove the four 5 mm Phillips screws from the external flash mount .
Slowly pull the bottom of the back case away from the camera.
Use the flat end of a spudger to pry the flat topped connector straight up from the motherboard.
Remove the back case.
3 участников успешно повторили данное руководство.
