Запчасти
Детали не указаны.
  1. Этот шаг не переведен. Помогите перевести
    Flip your laptop over so that the back  is face up.
    • Flip your laptop over so that the back is face up.
  2. Этот шаг не переведен. Помогите перевести
    Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate. Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Этот шаг не переведен. Помогите перевести
    Use a plastic opening tool to remove the back plate from the laptop. It is recommended that you start from a corner then run the tool along the  edge of the back plate.
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Этот шаг не переведен. Помогите перевести
    Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place. Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Этот шаг не переведен. Помогите перевести
    Use a spudger to pry the battery connecting cable from the laptop and remove the battery. Using the metal spudger may severely damage the internal components in your device. Using the metal spudger may severely damage the internal components in your device.
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
Финишная черта
4 участников успешно повторили данное руководство.
Alexander Ulman
Участник с: 16.09.2019
337 Репутация
Автор 2 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 19
За последние 30 дней: 92
За всё время: 2,205
