Введение
Replace a broken, cracked or frozen screen on your Samsung PL200 digital camera. Tools are required to access interior camera components.
Выберете то, что вам нужно
Remove the six 3 mm external screws from the camera base using the Phillips #000 screwdriver.
Remove the 3 mm screw holding the circuit board.
Use a pair of tweezers to detach the two ribbon cables connecting the circuit board to the camera.
Remove the circuit board.
Flip the LCD screen forward and remove the two 3 mm screws holding the metal midframe using a Phillips #000 screwdriver.
Remove the midframe using an opening tool.
Lift the black strip and the ribbon will easily come out.
After doing this, the LCD screen will be separated from the camera.
Еще один человек закончил это руководство.
