Введение
Replace the SD card on your Samsung PL200 to provide more memory space as well as replacing a defective card. This is a simple replacement that requires no tools and can be completed in less than 2 minutes.
Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
Once opened, the SD card should be visible.
Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector.
This will cause the SD card to raise up enough to allow you to grab it with your fingers.
Use your fingers to remove the old SD card.
Insert the new SD card into the SD card slot.
Make sure to push it down all the way until it clicks and remains flush with battery.
Close the battery/SD card compartment.
Еще один человек закончил это руководство.
