Введение
Acquire better quality of cleaning from your POWERbot with a clean brush. This can resolve the C 01 error code. The POWERbot's emergency switch should be turned off before handling the device.
Flip the device over to access the bottom of the vacuum with the brush compartment positioned close to you.
Press down on the outer edge of the brush cover to tilt the brush cover up. Grab the newly exposed inner edge and lift out the brush cover.
4 участников успешно повторили данное руководство.
5 Комментариев
How often should the power VR 7000 series self cleaning powerbrush be replace?
Without a part number, I cannot find a replacement brush.
Hi, Can anyone send me some info on a part number and where to get a replacement brush ~ Samsung POWERbot R7070 Power Brush Replacement?
Thanks much
