Введение
Replace the right driving wheel of your POWERbot to end movement problems . To resolve the C 03 error code, replace the right driving wheel.
Выберете то, что вам нужно
Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
Remove the two 1.5 cm screws above the yellow sliding lock tabs.
Remove the two 1.2 cm screws in the brush compartment.
With moderate force, separate the silver top from the black bottom of the vacuum.
Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
With the spring fully retracted, unhook the spring from the wheel casing.
Remove the screw securing the black plastic piece to the right of the wheel casing.
Lift wheel and wheel casing out of vacuum base.
Unscrew the black 1 cm screw securing the center of the wheel.
Remove the wheel.
7 участников успешно повторили данное руководство.
3 Комментариев
Where can you find the replacement left driving wheel? are all the model the same?
Very helpful, thank you.
Just beware of the rubber vacuum part and it’s placement after taking apart the vacuum.
