Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If the phone is regularly losing signal, one possibility is that the antennae is no longer functional and needs to be replaced. The antennae is also fragile and can gather dirt, which may cause it to break. This guide addresses both of these problems.
Запчасти
Детали не указаны.
  1. Slide the battery out from the battery compartment on the back of the phone. Slide the battery out from the battery compartment on the back of the phone.
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Unscrew the antenna top. Unscrew the antenna top.
    • Unscrew the antenna top.
  3. Clasp the antenna with tweezers and push toward the top. Remove the antenna. Remove the antenna.
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
Заключение
Kali Kupp
Участник с: 26.03.2014
316 Репутация
Автор 3 руководств
Команда
Clemson, Team 6-2, Benson Spring 2014 Участник Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 291
