Введение
If there is low or no sound from the speaker during regular calls and phone usage, then it may be that the speaker is broken and needs replacement. Follow this guide to check for any damage to the speaker, and, if necessary, to replace the speaker.
Запчасти
No parts specified.
  1. Slide the battery out from the battery compartment on the back of the phone. Slide the battery out from the battery compartment on the back of the phone.
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Unscrew the antenna top. Unscrew the antenna top.
    • Unscrew the antenna top.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Clasp the antenna with tweezers and push toward the top. Remove the antenna. Remove the antenna.
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  5. Remove the four screws (3 mm) from the battery compartment. Press the release buttons located on the side of the phone while gently prying the back plate off. Press the release buttons located on the side of the phone while gently prying the back plate off.
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  6. Press the release tabs on the sides of the back casing. Gently pry the motherboard loose and remove it. Gently pry the motherboard loose and remove it.
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  7. At the front plate of the phone, locate the internal speaker unit at the top of the front plate. Pry the internal speaker away from the front casing of the phone using a flathead screwdriver. Remove the internal speaker from the front casing.
    • At the front plate of the phone, locate the internal speaker unit at the top of the front plate.
    • Pry the internal speaker away from the front casing of the phone using a flathead screwdriver.
    • Remove the internal speaker from the front casing.
Заключение
Barbara
Участник с: 26.03.2014
413 Репутация
Автор 4 руководств
Команда
Clemson, Team 6-2, Benson Spring 2014 Member of Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 154
