Введение
HDD may need to be replaced if it is damaged or not working properly. Also upgrading to Solid State Drive (SSD) or a bigger capacity of HDD requires this replacement guide.
Выберете то, что вам нужно
Locate two notches above the battery.
Slide both battery locking notches to either side to remove the battery.
Pull the battery out.
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
