Введение
Optic drive replacement may need to be done when the drive is damaged.
Выберете то, что вам нужно
Locate two notches above the battery.
Slide both battery locking notches to either side to remove the battery.
Pull the battery out.
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Use the spudger or fingers to gently pull the optical drive out.
Slide the optic drive away from the laptop.
