Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your LED light strip on a Samsung Side By Side Refrigerator (model: RS25J500DSR) is not working, this guide will help you and lead you through your troubles. The LED light strip is an electric light for use in light fixtures. Inspect the connection connected to the LED light. Before starting, make sure to disconnect the refrigerator from the electrical outlet box. This guide provides easy and straightforward steps in changing the light on the fridge.
Remove the damaged LED light to insert the new one on the connection.
Be careful not to damage the clip from the connection when removing the LED light.
