Введение
The woofer speaker is responsible for all the deep bass sounds in your speaker, and if you hear any weird rattling or pinging noises there is a good chance your woofer speaker will need to be replaced. This guide will demonstrate how to replace the woofer speaker in the Samsung Radiant 360 R1.
Выберете то, что вам нужно
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
Remove the Port Panel from the speaker body, exposing the ribbon cables.
While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
Remove the eight (9.5mm x 1.66mm) PH1 Phillips screws on the right side of the speaker body.
Remove the one (9.5mm x 1.66mm) PH1 Phillips head screws on the left side of the speaker body.
Remove the four (9.5mm x 1.66mm) PH1 Phillips screws on the port speaker body.
Remove the Port Panel exposing the subwoofer.
Remove the ribbon cable from the subwoofer which is attached to the main motherboard.
Slide the subwoofer out of the enclosure.
3 участников успешно повторили данное руководство.
