Samsung Refrigerator Icemaker Assembly Replacement
Выберете то, что вам нужно
  1. Samsung Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: шаг 1, изображение 1 из 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: шаг 2, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: шаг 2, изображение 2 из 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: шаг 3, изображение 1 из 1
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
  4. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: шаг 4, изображение 1 из 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: шаг 4, изображение 2 из 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: шаг 4, изображение 3 из 3
  5. Samsung Refrigerator Icemaker Assembly Replacement, Check the ice bucket condition: шаг 5, изображение 1 из 1
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
  6. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: шаг 6, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: шаг 6, изображение 2 из 2
    • Remove the wire harness screw securing the cable cover panel.
  7. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: шаг 7, изображение 1 из 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: шаг 7, изображение 2 из 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: шаг 7, изображение 3 из 3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  8. Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: шаг 8, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: шаг 8, изображение 2 из 2
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  9. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: шаг 9, изображение 1 из 1
    • Remove the ice maker screw securing the air tunnel flap.
  10. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: шаг 10, изображение 1 из 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: шаг 10, изображение 2 из 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: шаг 10, изображение 3 из 3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  11. Samsung Refrigerator Icemaker Assembly Replacement: шаг 11, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement: шаг 11, изображение 2 из 2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  12. Samsung Refrigerator Icemaker Assembly Replacement: шаг 12, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement: шаг 12, изображение 2 из 2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  13. Samsung Refrigerator Icemaker Assembly Replacement: шаг 13, изображение 1 из 3 Samsung Refrigerator Icemaker Assembly Replacement: шаг 13, изображение 2 из 3 Samsung Refrigerator Icemaker Assembly Replacement: шаг 13, изображение 3 из 3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  14. Samsung Refrigerator Icemaker Assembly Replacement: шаг 14, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement: шаг 14, изображение 2 из 2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  15. Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: шаг 15, изображение 1 из 2 Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: шаг 15, изображение 2 из 2
Заключение
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
2 человек успешно провели ремонт по этому руководству.
nicO
Участник с: 04/14/15
15 945 Репутация
Автор 89 руководств
Команда
Team Vulcan Участник Team Vulcan
Staff
6 членов
Автор 212 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 29
За последние 7 дней: 189
За последние 30 дней: 762
За всё время: 19,902
