Введение
This guide will provide a step-by-step procedure for replacing the antenna and speaker in your Samsung Rogue.
Выберете то, что вам нужно
With your thumbs, push down on the back cover of your phone and slide it away from the camera.
Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
On the underside of the motherboard, remove the single 3.3mm Philips screw.
Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
