Введение
This guide will take you through the steps of removing parts of your device to reach and replace the lens
Выберете то, что вам нужно
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Locate and remove the six 4mm screws on the sides of the camera.
Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
Once the back case is removed, use the plastic opening tool to gently pry off the front case.
Move the screen down, out of the way to remove the two 3mm screws beneath it.
Remove the 6mm screw labeled in the picture.
Remove the three 3mm screws.
Then proceed to flip the screen to the other side to remove the other 6mm screw.
Proceed to carefully pull the ribbon cable out by using the little circular tabs sticking out on either side.
Proceed to slowly pry off the mother board with the plastic opening tool by removing it at the micro USB attachment.
Then carefully manually pry off the golden colored section near the camera wheel until all of it is off.
Finally, remove the final 3mm screw marked in the picture.
Lift the camera lens out of the lens compartment.
4 участников успешно повторили данное руководство.
2 Комментариев
Brilliantly explained. Makes it look so easy… even a fool such as I could follow the instructions.
the guide is actually beautiful im just upset that mine got corroded from battery leakage and rusted the capacitors next to the charging port and caused it to fall off :c
