Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove 4 screws from bottom of camera
Remove 2 screws from side of camera
Squeeze area noted by blue square and pull outside shell apart from remaining camera.
Remove 6 screws identified by red circles
Remove 3 screws identified by orange circles
Gently remove orange circuit ribbon identified by red square
Gently remove narrow orange circuit ribbon identified by blue square
Using a soldering iron, remove solder from wire identified by red circle
Using a soldering iron, remove solder from black and red wire identified by orange circle
Using a soldering iron, remove solder from wire identified by yellow circle
Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
Repeat step two to three times until board feels flexible to bend
Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
Remove black rubber door located on side of camera closest to lens using tweezers.
Еще один человек закончил это руководство.
