Введение
The lens of a camcorder is one of the most important components of the device. However, the lens is also susceptible to cracking and becoming dirty. A dirty/cracked lens may affect the outcome of the photographed results, so a replacement may be in order.
When the lens of a Samsung camcorder are damaged or non-functional, it would need to be replaced. This guide will show you how to remove the lens in your camcorder.
Выберете то, что вам нужно
Unplug the cord connecting the LCD section of the device.
Remove the left face of the device.
Remove the top face by removing the three 4mm screws using a Phillips #000 screwdriver.
After removing the body of the device, unscrew the two 3.5mm Phillips #000 screws holding the battery compartment in place.
Remove the battery compartment.
Remove the three 3.5mm Phillips #000 screws on the metal part from the lens component.
Remove the motherboard from the lens.
Remove the lens from the lens assembly.
