Введение
It may become necessary to replace the logic board on this cell phone in order to correct a problem. Following this guide will make removal quite easy.
Выберете то, что вам нужно
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
Then disconnect the small power connector near the top of the phone.
Еще один человек закончил это руководство.
