Введение
This guide will teach you how remove your Samsung's SCH-A950's Volume and Camera Buttons.
  1. Slide the the battery release tab upwards while simultaneously lifting the back cover straight up. Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Remove the four Phillips #00 screws underneath the battery.
    • Remove the four Phillips #00 screws underneath the battery.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Купить сейчас
    iPhone X Fix Kits
    Купить сейчас
  4. Pull open the earphone tab and the Trans Flash tab using your fingers. Pull open the earphone tab and the Trans Flash tab using your fingers.
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  5. Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  6. Using tweezers or your fingers, lift off buttons from logic board. The buttons can be replaced if needed. The buttons can be replaced if needed.
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
Заключение
Sean Kennedy
Участник с: 13.01.2010
49 Репутация
1 Guide authored
Команда
Cal Poly, Team 11-5, Forte Winter 2010 Member of Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,765
