Введение
The disassembly of the covers will be needed to replace/repair anything on the Samsung SCV-VLUUST50, not including the battery.
Выберете то, что вам нужно
Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
Remove the corner panel by applying pressure away from the shutter button.
Remove the top panel by applying gentle pressure away from the shutter button.
Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
