Введение
Items needed:
You will need a wedge shaped tool in order to pry open the front panel of cell phone and a screwdriver.
Выберете то, что вам нужно
Remove the plastic coverings at the base of the LCD screen using your fingers.
Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
Gently pry the top panel off around the entire frame.
Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
