Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Introduction
This guide will teach readers on how to replace the face plate of their Samsung SGH-X495. It will explain how to identify push pins and tabs and also how to remove them.
Запчасти
Детали не указаны.
  1. First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  2. Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. As shown above, with a plastic pry tool, begin working at the top corner and down each side.  The face plate has 10 tabs that hook into the phone's body. Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
  5. Continue down each side toward the bottom with your pry tool. Note: It may help to use multiple pry tools to help hold it open.
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
  6. With 8 tabs released, the face plate is nearly free. With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
Заключение
Matthew Hove
Участник с: 05.01.2011
1 031 Репутация
Автор 10 руководств
Команда
Cal Poly, Team 3-40, Regan Winter 2011 Участник Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 членов
Автор 20 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,964
