Samsung SPEX SCH-R210 Speaker Replacement
Выберете то, что вам нужно
  1. Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: шаг 1, изображение 1 из 3 Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: шаг 1, изображение 2 из 3 Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung SPEX SCH-R210 Speaker Replacement, Battery: шаг 2, изображение 1 из 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung SPEX SCH-R210 Speaker Replacement: шаг 3, изображение 1 из 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
  4. Samsung SPEX SCH-R210 Speaker Replacement, Speaker: шаг 4, изображение 1 из 1
    • Use a Phillips #00 screwdriver to unscrew the four 3/16" screws holding the black plastic cover of the phone in place.
  5. Samsung SPEX SCH-R210 Speaker Replacement: шаг 5, изображение 1 из 2 Samsung SPEX SCH-R210 Speaker Replacement: шаг 5, изображение 2 из 2
    • Remove the small, black headphone cover from the left side of the phone by gently pulling it off.
    • Remove the small, black volume cover from the right side of the phone by gentle pulling it off.
  6. Samsung SPEX SCH-R210 Speaker Replacement: шаг 6, изображение 1 из 1
    • Remove the black plastic cover from the back of the phone by slowly pulling it off. This may take a little effort.
  7. Samsung SPEX SCH-R210 Speaker Replacement: шаг 7, изображение 1 из 1
    • Once removed, turn the cover over so that the insides are visible.
    • Using your fingernail, pry out the small, grey, circular speaker from the cover.
  8. Samsung SPEX SCH-R210 Speaker Replacement: шаг 8, изображение 1 из 1
    • Remove the old speaker, discard it and replace it with a new speaker.
Заключение
Susan
Участник с: 07/11/13
301 Репутация
Автор 3 руководств
Команда
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Участник WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 243
