Samsung SPH-A640 Screen Replacement
Выберете то, что вам нужно
  1. Samsung SPH-A640 Screen Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Press and hold the “End” button until the phone powers off.
  2. Samsung SPH-A640 Screen Replacement: шаг 2, изображение 1 из 2 Samsung SPH-A640 Screen Replacement: шаг 2, изображение 2 из 2
    • Turn the phone over on its backside.
    • Remove the bottom cover by sliding it downward, and then remove the battery.
  3. Samsung SPH-A640 Screen Replacement, Screen: шаг 3, изображение 1 из 1
    • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
  4. Samsung SPH-A640 Screen Replacement: шаг 4, изображение 1 из 1
    • Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
    • Disengaging the clips near the hinge may require some force.
  5. Samsung SPH-A640 Screen Replacement: шаг 5, изображение 1 из 1
    • Using tweezers, carefully remove the buttons from both sides while removing the back cover.
    • Note the positions of the buttons. They must be returned to the same positions.
  6. Samsung SPH-A640 Screen Replacement: шаг 6, изображение 1 из 1
    • Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
  7. Samsung SPH-A640 Screen Replacement: шаг 7, изображение 1 из 1
    • Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
  8. Samsung SPH-A640 Screen Replacement: шаг 8, изображение 1 из 1
    • Remove the front cover of the phone using a plastic opening tool.
    • Slide a plastic opening tool along the seam from the hinge around the perimeter.
  9. Samsung SPH-A640 Screen Replacement: шаг 9, изображение 1 из 1
    • Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
  10. Samsung SPH-A640 Screen Replacement: шаг 10, изображение 1 из 2 Samsung SPH-A640 Screen Replacement: шаг 10, изображение 2 из 2
    • Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
  11. Samsung SPH-A640 Screen Replacement: шаг 11, изображение 1 из 2 Samsung SPH-A640 Screen Replacement: шаг 11, изображение 2 из 2
    • Using a plastic opening tool, lift the screen assembly from the case.
    • To the best of our knowledge, remove the hinge to free the ribbon cable from the case and remove the screen assembly.
Заключение
Geoff Wiggins
Участник с: 02/13/14
1 Репутация
1 руководство автора
Команда
Ohio State, Team 1-2, Meza Spring 2014 Участник Ohio State, Team 1-2, Meza Spring 2014
OSU-MEZA-S14S1G2
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 9
За всё время: 384
