Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Samsung SPH-M360 Case Replacement
Выберете то, что вам нужно
  1. Samsung SPH-M360 Case Replacement, Remove the back battery panel from the phone.: шаг 1, изображение 1 из 2 Samsung SPH-M360 Case Replacement, Remove the back battery panel from the phone.: шаг 1, изображение 2 из 2
    • Detach the battery cover by sliding the cover down toward the bottom of the phone.
    • Slide back cover in direction of arrow.
    • Lift up on the battery cover to complete cover removal.
  2. Samsung SPH-M360 Case Replacement, Remove the battery.: шаг 2, изображение 1 из 2 Samsung SPH-M360 Case Replacement, Remove the battery.: шаг 2, изображение 2 из 2
    • Remove battery by lifting up in the corner of the battery.
    • Use the semi-circle provided in order to gain access to the battery.
    • Battery will come out at an angle. This does not require force.
  3. Samsung SPH-M360 Case Replacement, Unscrew the case: шаг 3, изображение 1 из 1
    • Use a phillips head (PH) #00 screwdriver to remove four screws connecting the two halves of the case.
    • Note: keep the screws in a safe location, where they will not be lost until needed for reassembly.
  4. Samsung SPH-M360 Case Replacement, Remove the back half of the case.: шаг 4, изображение 1 из 3 Samsung SPH-M360 Case Replacement, Remove the back half of the case.: шаг 4, изображение 2 из 3 Samsung SPH-M360 Case Replacement, Remove the back half of the case.: шаг 4, изображение 3 из 3
    • Using your plastic opening tool, pry under the back case starting with the top as marked by red circle.
    • There is a small clip at the top of the phone that must be released in order to remove the back case.
    • The volume button and camera button are held in by the back case. Volume button pictured. Camera button opposite.
    • REASSEMBLY ONLY: Replace volume and camera buttons in place. Then, insert the top of the back case FIRST and squeeze together clips as you work toward the bottom of the phone.
Заключение
Tyler Long
Участник с: 10/06/14
109 Репутация
1 руководство автора
Команда
Plato Участник Plato
Community
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 200
