Введение
Follow this guide if you want to replace the back cover of your Samsung Series 5 3G Chromebook. Removing the back cover exposes all the internal components of the laptop. Make sure your Chromebook is powered off before you begin.
Выберете то, что вам нужно
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel using your fingernails.
Remove all the seven screws from the bottom panel.
3 участников успешно повторили данное руководство.
