Введение
Outline what you are going to teach someone how to do.
Запчасти
Никакие детали не требуются.
  1. Make sure your Chromebook is powered off before you begin.
    • Make sure your Chromebook is powered off before you begin.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
    • Remove all the seven screws in the bottom panel.
  2. Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Once you work your way around, you can remove the panel.
    • Remove the single Phillip screw
    • Disconnect the WWAN antennas from the I/O board
    • Remove the WWAN board from the motherboard.
Заключение
2 участников успешно повторили данное руководство.
Helder Avelino
Участник с: 22.10.2013
849 Репутация
Автор 5 руководств
Команда
University of Maryland, Team 1-7, Shastany Fall 2013 Member of University of Maryland, Team 1-7, Shastany Fall 2013
UMD-SHASTANY-F13S1G7
2 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 548
