Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel using your fingernails.
Remove all the seven screws from the bottom panel.
Remove the single Phillip screw
Disconnect the WWAN antennas from the I/O board
Remove the WWAN board from the motherboard.
2 участников успешно повторили данное руководство.
