Samsung Series 5 UltraTouch Battery Replacement
Выберете то, что вам нужно
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: шаг 1, изображение 1 из 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: шаг 1, изображение 2 из 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
    The user manual recommends, before removing the cover:
    "Insert an object, such as a paper clip, into the Emergency Hole at the bottom of the computer to cut the battery power. If the Power button does not work anymore, that means you successfully shut the power off."
    This seems to make sure power is completely off or something. The hole can be seen in the picture; it is located in the center, very near where the screwdriver is.
    Pachi - Ответить
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: шаг 2, изображение 1 из 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: шаг 2, изображение 2 из 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: шаг 3, изображение 1 из 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: шаг 3, изображение 2 из 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: шаг 4, изображение 1 из 2 Samsung Series 5 UltraTouch Battery Replacement: шаг 4, изображение 2 из 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: шаг 6, изображение 1 из 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: шаг 7, изображение 1 из 1
    • Remove the battery from the laptop.
Заключение
14 участников успешно повторили данное руководство.
Timothy
Участник с: 01/30/15
1 579 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 16-3, Watkins Winter 2015 Участник USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 членов
Автор 5 руководств
2 Комментариев
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Ответить
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 60
За всё время: 26,800
