Введение
If your computer is no longer holding a charge or is dying quickly without a charger, then you should replace the battery. This guide will help you replace the battery.
Выберете то, что вам нужно
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
Remove the last three remaining 0.1mm screws attached to the battery.
Find the battery's output plug, and use a spudger or pointed precision tool to press on the indention in the middle of the plug to unlock.
Remove the connection from the motherboard and the battery, by carefully placing both hands on the wires and tug on the wires.
Remove the battery and place it from the laptop. At this point you can replace the battery with a new one.
Еще один человек закончил это руководство.
