Samsung Series 9 NP900X3A Laptop Battery Replacement
Выберете то, что вам нужно
  1. Samsung Series 9 NP900X3A Laptop Battery Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 3, изображение 1 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 3, изображение 2 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 3, изображение 3 из 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A Laptop Battery Replacement, Laptop Battery: шаг 4, изображение 1 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement, Laptop Battery: шаг 4, изображение 2 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement, Laptop Battery: шаг 4, изображение 3 из 3
    • Remove the last three remaining 0.1mm screws attached to the battery.
    • Keep track of the screws and remember their placement. This will make it easier to replace the battery.
  5. Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 5, изображение 1 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 5, изображение 2 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 5, изображение 3 из 3
    • Remove the battery from the laptop by prying it out from its compartment.
    • The battery should be loose and can move for the next step.
    • You will need to use force to pry open the battery.
  6. Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 6, изображение 1 из 2 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 6, изображение 2 из 2
    • Find the battery's output plug, and use a spudger or pointed precision tool to press on the indention in the middle of the plug to unlock.
    • Do not press too hard unlocking the plug or you will puncture plug's pins ruining the connector.
  7. Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 7, изображение 1 из 2 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 7, изображение 2 из 2
    • Remove the connection from the motherboard and the battery, by carefully placing both hands on the wires and tug on the wires.
    • You will need to use some force, be cautious when removing this component. Pull the plug out slowly while applying pressure with the tool in necessary.
  8. Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 8, изображение 1 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 8, изображение 2 из 3 Samsung Series 9 NP900X3A Laptop Battery Replacement: шаг 8, изображение 3 из 3
    • Remove the battery and place it from the laptop. At this point you can replace the battery with a new one.
Заключение
Еще один человек закончил это руководство.
Zahir Sanchez
Участник с: 02/08/18
493 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S2-G4, Thomas Spring 2018 Участник University of North Texas, Team S2-G4, Thomas Spring 2018
UNT-THOMAS-S18S2G4
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 15
За последние 30 дней: 45
За всё время: 3,840
