Samsung Series 9 NP900X3A Memory Card Replacement
Выберете то, что вам нужно
  1. Samsung Series 9 NP900X3A Memory Card Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 3, изображение 1 из 3 Samsung Series 9 NP900X3A Memory Card Replacement: шаг 3, изображение 2 из 3 Samsung Series 9 NP900X3A Memory Card Replacement: шаг 3, изображение 3 из 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A Memory Card Replacement, USB & Headphone I/O Board: шаг 4, изображение 1 из 1
    • Locate the AUX and USB port on the left side of the laptop.
  5. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 5, изображение 1 из 1
    • Remove the one 0.1mm screw using a Phillips #0 Screwdriver from the laptop.
    • Keep track of the 0.1mm screws for reassembly later.
  6. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 6, изображение 1 из 1
    • Use a plastic prying tool to remove the top connector of the port from the motherboard.
    • This should come out very easily and allow access to the Memory card.
  7. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 7, изображение 1 из 1
    • Remove the second connector from the motherboard using the prying tool.
    • This should come out very easily, and allow access to the Memory card.
  8. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 8, изображение 1 из 2 Samsung Series 9 NP900X3A Memory Card Replacement: шаг 8, изображение 2 из 2
    • Find an opening on the side of the port and pry the USB and AUX port out of the laptop with the prying tool.
  9. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 9, изображение 1 из 1
    • Remove and place the port outside of the laptop. You are free to install your new USB and HDMI ports.
  10. Samsung Series 9 NP900X3A Memory Card Replacement, Memory Card: шаг 10, изображение 1 из 1
    • Using your Phillips #0 Screwdriver, unscrew the 0.1mm screws securing the memory card in place at the top.
    • Remember to keep track of the screws for reassembly.
  11. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 11, изображение 1 из 3 Samsung Series 9 NP900X3A Memory Card Replacement: шаг 11, изображение 2 из 3 Samsung Series 9 NP900X3A Memory Card Replacement: шаг 11, изображение 3 из 3
    • After removing the screws, your card should angle upward making for an easier removal.
    • Using both hands, gently lift the card out of its socket in the direction away from yourself.
    • Use caution when removing the card, bending the pins will damage the socket and your ability to reuse the memory card if you plan to.
  12. Samsung Series 9 NP900X3A Memory Card Replacement: шаг 12, изображение 1 из 1
    • Replace the the card with a new compatible memory card.
    • To install your new memory card, follow these steps in reverse order.
Заключение
2 участников успешно повторили данное руководство.
Austin Gross
Участник с: 02/08/18
228 Репутация
1 руководство автора
Команда
University of North Texas, Team S2-G4, Thomas Spring 2018 Участник University of North Texas, Team S2-G4, Thomas Spring 2018
UNT-THOMAS-S18S2G4
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 15
За всё время: 1,137
