Введение
In this guide, we will be showing you how to replace the display on the Samsung Series 9 NP900X4D-A03US. We begin by removing the adhesive frame from the display, unscrewing the screws holding the display in place, and detaching the cable that keeps it intact.
Выберете то, что вам нужно
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Use an iFixit opening tool to carefully remove the back panel from the laptop.
Lightly place some pressure into the highlighted cavity on the battery's outlet plug with a spudger.
Carefully remove the wires from the outlet plug.
Now you will be able to remove the battery from its place.
Use the Phillips #00 screwdriver to unscrew the four 2.5mm screws.
Gently remove the tabs from each corner.
Use the iFixit opening tool to detach the screen from the frame.
Slowly lay the screen down on the keyboard.
Using tweezers, slowly remove the connected wire from the display.
Gently remove the display from the device.
Еще один человек закончил это руководство.
3 Комментариев
Good day
Where can I buy the screen?
My laptop model number is NP900X4D-A01ZA
Your assistance will be highly appreciated
Kind regards
is not easy to get that screen i think it needs a special screen
How Can I get that screen or any other related Screen ?
