Введение
The RAM, or memory, has a significant effect on your laptop’s performance, so if you’re having issues, you may want to replace your RAM or upgrade it.
Выберете то, что вам нужно
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Use an iFixit opening tool to carefully remove the back panel from the laptop.
Lightly place some pressure into the highlighted cavity on the battery's outlet plug with a spudger.
Carefully remove the wires from the outlet plug.
Now you will be able to remove the battery from its place.
Move aside the two metal retaining clips.
Pull the RAM stick out to remove it.
