Введение
Steps how to replace the SmartCam Speakers incase of malfunction.
Выберете то, что вам нужно
Remove the mount.
Use the mount replacement guide if necessary to take the mount off.
At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
Once the spudger is in, gently pry it open.
Work your way around the SmartCam with the spudger loosing 8 clips.
The speaker should be attached to the cover with red and black wires going to the main board.
Unscrew the two screws holding the speaker in place.
Gently take the speaker out of the cover.
Take out the red and black wires from a small plug-in on the main board.
2 участников успешно повторили данное руководство.
Один комментарий
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
