Введение
Samsung S5230 Star.
How to dis-assembly and change the Touch Screen. Full video you ca see here:
Инструменты
Запчасти
Детали не указаны.
Видео обзор
  1. Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws. Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws. Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
    • Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
  2. After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board. After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board. After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
    • After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
  3. Unstuck camera keys and remove the middle bezel. Unstuck camera keys and remove the middle bezel. Unstuck camera keys and remove the middle bezel.
    • Unstuck camera keys and remove the middle bezel.
  4. Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down. Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
    • Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
  5. On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation. On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation. On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
    • On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
  6. Now is easy to remove the touch screen. Now is easy to remove the touch screen.
    • Now is easy to remove the touch screen.
  7. Install new touch screen and assembly the phone. Install new touch screen and assembly the phone. Install new touch screen and assembly the phone.
    • Install new touch screen and assembly the phone.
Заключение
10 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
184 253 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
307 членов
Автор 1 105 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 3,454
