  1. Turn the Samsung Sway over to access the rear cover.
    • Turn the Samsung Sway over to access the rear cover.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  3. Using your thumb, slide the cover away from the device, and then place the cover to the side. Using your thumb, slide the cover away from the device, and then place the cover to the side.
    • Using your thumb, slide the cover away from the device, and then place the cover to the side.
  4. Grip the corner of the battery on either the left or right side with your fingers and lift it up to remove it.
    • Grip the corner of the battery on either the left or right side with your fingers and lift it up to remove it.
Заключение
To reassemble your device, insert new battery and slide the back cover back on to the device
Chris Rush
Участник с: 27.06.2013
301 Репутация
Автор 3 руководств
Команда
WRI115, Team 1-2, Ruszkiewicz Spring 2013 Member of WRI115, Team 1-2, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G2
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 192
