Выберете то, что вам нужно
Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
