Samsung U28E510 Jog Button Replacement
Выберете то, что вам нужно
  1. Samsung U28E510 Jog Button Replacement, Jog Button: шаг 1, изображение 1 из 3 Samsung U28E510 Jog Button Replacement, Jog Button: шаг 1, изображение 2 из 3 Samsung U28E510 Jog Button Replacement, Jog Button: шаг 1, изображение 3 из 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: шаг 2, изображение 1 из 2 Samsung U28E510 Jog Button Replacement: шаг 2, изображение 2 из 2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: шаг 3, изображение 1 из 1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
Заключение
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 участников успешно повторили данное руководство.
Jake Ritter
Участник с: 01/22/18
106 Репутация
1 руководство автора
Команда
Cal Poly, Team S11-G1, Banghart Winter 2018 Участник Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 членов
Автор 6 руководств
5 Комментариев
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Ответить
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Ответить
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - Ответить
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 21
За последние 30 дней: 84
За всё время: 6,521
