Введение
The battery should be replaced if it fails to hold a charge or appears to be corroded in any way.
Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
Twist the nob counter-clockwise while pushing cover to the left. Then pull the cover up to reveal the battery.
Carefully slide the battery out of the camera. It can then be replaced with a new battery.
