Samsung WB2200F LCD Screen Replacement
Выберете то, что вам нужно
  1. Samsung WB2200F LCD Screen Replacement, Face-plate: шаг 1, изображение 1 из 3 Samsung WB2200F LCD Screen Replacement, Face-plate: шаг 1, изображение 2 из 3 Samsung WB2200F LCD Screen Replacement, Face-plate: шаг 1, изображение 3 из 3
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  2. Samsung WB2200F LCD Screen Replacement: шаг 2, изображение 1 из 1
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  3. Samsung WB2200F LCD Screen Replacement: шаг 3, изображение 1 из 1
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  4. Samsung WB2200F LCD Screen Replacement, LCD Screen: шаг 4, изображение 1 из 1
    • Using the the screw driver with the JIS size 000 head, unscrew each and every 6mm screw surrounding the LCD screen after taking off the face plate.
  5. Samsung WB2200F LCD Screen Replacement: шаг 5, изображение 1 из 1
    • The LCD screen has two layers; the screen on top and the metallic screen protector it lays in. Make sure to take out the screw to the right of both layers that link them together.
  6. Samsung WB2200F LCD Screen Replacement: шаг 6, изображение 1 из 1
    • Disconnect the faulty screen from the metallic compartment as well as the motherboard of the camera.
  7. Samsung WB2200F LCD Screen Replacement: шаг 7, изображение 1 из 1
    • Place the new screen inside the metallic compartment and make sure it fits perfectly on each side.
  8. Samsung WB2200F LCD Screen Replacement: шаг 8, изображение 1 из 1
    • Proceed to insert and tighten screws around the screen which has been placed inside its metallic compartment. Be sure to screw in the main 0.4cm screw that connects both the LCD screen and metallic screen together first.
Заключение
Rudolf Boampong
Участник с: 03/04/16
195 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 5-4, Landers Spring 2016 Участник UMass Dartmouth, Team 5-4, Landers Spring 2016
UMASSD-LANDERS-S16S5G4
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 334
