Введение
Replacing A Drain Pump
Выберете то, что вам нужно
Drain any excess water preferably outside, using the cap on the side of the washing washine
Once drained, put the cap aside. Now flip the washing machine onto it's front side
Remove the 3 screws at the bottom of the washing machine where the drain hose was.
Inside the washing machine there two hose connected to the drain pump assembly, remove them.
Disconnect the two wires that give the drain pump power and unscrew the protective cover after this
Once you have the unit free, there are 3 screws connecting the pump to the other part of the drain pump assembly . unscrew the three screws
Now your pump is free. Replace the pump and put everything back together.
You have successfully replaced your drain pump
https://www.samsung.com/ae/support/model... follow the link above for guides and FAQ
Еще один человек закончил это руководство.
