Samsung Washing Machine WA80U3 Water Drain Pump Replacement
Выберете то, что вам нужно
    • Drain any excess water preferably outside, using the cap on the side of the washing washine
    • Once drained, put the cap aside. Now flip the washing machine onto it's front side
    • Remove the rear cover
    • Now remove the 2 screws where you took out the cap and the drain hose
    • Remove the 3 screws at the bottom of the washing machine where the drain hose was.
    • Inside the washing machine there two hose connected to the drain pump assembly, remove them.
    • Disconnect the two wires that give the drain pump power and unscrew the protective cover after this
    • Liberate the unit out by moving it to the left, up while lifting it out
    • Once you have the unit free, there are 3 screws connecting the pump to the other part of the drain pump assembly . unscrew the three screws
Заключение
Еще один человек закончил это руководство.
Neville Davids
Участник с: 07/02/18
181 Репутация
1 руководство автора
Один комментарий
I'm Sorry For The Lack Of Pictures.
Neville Davids - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 1,198
