Samsung Watch Active Motherboard Replacement
Выберете то, что вам нужно
  1. Samsung Watch Active Motherboard Replacement, Turn off the watch: шаг 1, изображение 1 из 2 Samsung Watch Active Motherboard Replacement, Turn off the watch: шаг 1, изображение 2 из 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Motherboard Replacement, Remove the rear screws: шаг 2, изображение 1 из 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Watch Active Motherboard Replacement, Separate the back cover from the housing: шаг 3, изображение 1 из 3 Samsung Watch Active Motherboard Replacement, Separate the back cover from the housing: шаг 3, изображение 2 из 3 Samsung Watch Active Motherboard Replacement, Separate the back cover from the housing: шаг 3, изображение 3 из 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Watch Active Motherboard Replacement, Disconnect the sensor array: шаг 4, изображение 1 из 2 Samsung Watch Active Motherboard Replacement, Disconnect the sensor array: шаг 4, изображение 2 из 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Motherboard Replacement, Remove the back cover: шаг 5, изображение 1 из 1
    • Remove the back cover.
  6. Samsung Watch Active Motherboard Replacement, Disconnect the motherboard: шаг 6, изображение 1 из 3 Samsung Watch Active Motherboard Replacement, Disconnect the motherboard: шаг 6, изображение 2 из 3 Samsung Watch Active Motherboard Replacement, Disconnect the motherboard: шаг 6, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the display assembly, the microphone and pressure sensor array, and side button.
  7. Samsung Watch Active Motherboard Replacement, Undo the mic tape: шаг 7, изображение 1 из 3 Samsung Watch Active Motherboard Replacement, Undo the mic tape: шаг 7, изображение 2 из 3 Samsung Watch Active Motherboard Replacement, Undo the mic tape: шаг 7, изображение 3 из 3
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Samsung Watch Active Motherboard Replacement, Remove the motherboard screw: шаг 8, изображение 1 из 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  9. Samsung Watch Active Motherboard Replacement, Loosen the motherboard: шаг 9, изображение 1 из 3 Samsung Watch Active Motherboard Replacement, Loosen the motherboard: шаг 9, изображение 2 из 3 Samsung Watch Active Motherboard Replacement, Loosen the motherboard: шаг 9, изображение 3 из 3
    • Use an opening pick to loosen the motherboard from the core assembly.
    • The plastic tab holding the motherboard in place is fragile, so don't lift the motherboard up until it has cleared the tab.
  10. Samsung Watch Active Motherboard Replacement, Remove the motherboard: шаг 10, изображение 1 из 3 Samsung Watch Active Motherboard Replacement, Remove the motherboard: шаг 10, изображение 2 из 3 Samsung Watch Active Motherboard Replacement, Remove the motherboard: шаг 10, изображение 3 из 3
    • Slide the motherboard out from under the plastic tab to remove it.
Заключение
3 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
117 296 Репутация
Автор 188 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 521 руководств
Один комментарий
Sir can you help ME with power switch lines
Tupper Mendoza - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 11
За последние 30 дней: 37
За всё время: 2,205
